as above,
thanks stephen
how to remove door card
Re: how to remove door card
did it ages ago lets see if i can remember
take out the door handle, use a screw driver or something flat and cover it with a cloth to push is up and off. There will be two screws i think behind each one.
there are 4/5 screws on the bottom of the door card just unscrew them.
I think thats it for screws im sure someone else can confirm.
Then just ease the door off with the assistance of screwdriver and cloth again, there are loads of black popper type things around the door card.
Or just buy a haynes manual.
There are two torx screws I think there t27? maybe t30?? Two on the passenger handle just used something flat or pull hard towards yourself, drivers side pull the handle upwards and there another two there, then as above theres four torx screws I think there t25? just whip them out and then pull the doorcards upwards.
