My polo has the handbrake light, and the abs light on permanently. Ive changed the abs controlmodyle,and checked all the fuses, which are fine.
My abs sensors are all working, so I'm wondering why the lights are still on?
Is it a fault code that still needs to be cleared?
Thanks for any info.
abs light.
abs light.
Could be but mine usually turns off anyway. Have you had a code read? Best to do that and also check your fluid levels
- joe2612
- Location: Guildford, Surrey, Drives: Polo GTI 6n2 Black
Re: abs light.
You'll probably need to clear the fault code in vagcom.
