Currently looking at some schmidt th lines,
The fronts are 8jx16 et20, rears 9jx16 et18
will these fit without any rubbing problems?
they are 5x100 so wouldnt need adaptors!
cheers
Will these fit?
Re: Will these fit?
Sounds rather wide, but you would have to see
Re: Will these fit?
You'll need camber shims on the back and front and they should fit sweet as a nut mate!
Re: Will these fit?
Yeah they should hopefully, im just shoppin about atm dont know what to get !
im looking at some other ones that are 7jx16 et25 offset, but ill need adaptors! which will take the offset down to et10 if i get the 15mm ones!
would they fit alright? :S
Re: Will these fit?
Not sure about the et: but the 9" at the back will fit with 205/40/17
