UK-POLOS.NET - THE VW Polo Forum • Will these fit?
Will these fit?
Posted: Sun Aug 14, 2011 7:30 pm
by Sharpy19
Currently looking at some schmidt th lines,
The fronts are 8jx16 et20, rears 9jx16 et18
will these fit without any rubbing problems?
they are 5x100 so wouldnt need adaptors!
cheers
Re: Will these fit?
Posted: Sun Aug 14, 2011 9:49 pm
by ali123
Sounds rather wide, but you would have to see
Re: Will these fit?
Posted: Mon Aug 15, 2011 3:51 pm
by matt_123
You'll need camber shims on the back and front and they should fit sweet as a nut mate!
Re: Will these fit?
Posted: Tue Aug 16, 2011 8:15 am
by Sharpy19
Yeah they should hopefully, im just shoppin about atm dont know what to get !
im looking at some other ones that are 7jx16 et25 offset, but ill need adaptors! which will take the offset down to et10 if i get the 15mm ones!
would they fit alright? :S
Re: Will these fit?
Posted: Fri Aug 19, 2011 8:23 am
by spermbank
Not sure about the et: but the 9" at the back will fit with 205/40/17
