hi guys
bit annoyed really just had my car serviced by vag for £490... and a few days later my oil light as started flashing orange on start up
checked book and it said the part needed replacement.
shouldnt they have checked this?
any how
any one know what part it is i need to replace?
oil light
Re: oil light
Isn't orange oil lamp a level warning? And technically no its not considered part of a service if there was no fault showing, if wasnt doing it when it left them then theres not a lot that they can do about it. It could just be a really bad coincidence its happened so shortly after.
I know it sounds daft and you might have already done it but check the oil level.
I'm not one to stick up for dealers btw
If the oil level is ok according to the dipstick then it may well be a new level sensor or something
Re: oil light
yeah it is the oil lamp, but its flashing not staying on.
ive checked oil level and it just had an oil change so i pressumed the levels were fine,
ill check them again
thanks
thanks
geo stronach
- Drives: 2003 polo
Re: oil light
Mine does this just when engine has been started and am sure it's part of the checks when starting
Sent from my SM-G900F using Tapatalk
