Hi again.. @ trottagi, yeah I believe last time it was scanned it threw up a lambda sensor fault, I fitted a new one (front) had the codes cleared, and it went away, for about 10 starts of the car, then it came on again.. 10 mire starts, and guess what.. Away it goes.. Starting to think the second one needs replacing now too..
Neil, I'm in Bristol, yate to be precise, and I don't have access to a vagcom yet.. My other half's dad is a mech so did the clearing for me.. And yes it did throw the hydraulic pump code, I have had the unit apart(it was still sealed) sorted the dry solder properly, without excessive heat application, and then the abs light went out on ignition, now only comes on over 25mph.. So am thinking a sensor is to blame, hence ordering a full set, as I like to do things right
I was meaning to ask advice on vagcom, as I want one for myself for the future. Is it advisable to opt for a cheap hand held unit (like the ones i see posted around on here) Or is it better to get a cable interface and software for the laptop?? If so what would you reccommend??
I am in the process of re colour coding mirrors and badges in an Audi black pearl, wheels will be going the same colour, and when I replace that strut, down she will go
oh and the ice... Can't forget the ice..
