As im stripping my polo 6n ready for scrapping in december when the tax is up, i have re-fitted my standard brakes so these are off ready to go, polo 6n2 16v 256mm front brake set up, will fit 6n (thats what i had them on) hubs, calipers, carriers, disks, pads, flexi pipes, bottom ball joints, the abs sensors are still in the hubs also if you have abs, didnt on mine. quick bolt up and bleed mod. made a massive difference over standard 239mm, and as the caliper carriers are bolt ups, the hubs are ripe for a 280mm set up if thats strokes your fancy.
Ignore the surface rust in the pics, they were fitted a 2 weeks after i took them off the host car, and had gathered a bit of ginger while waiting for me to pull my finger out. also theres a bit of grease on the back of one of the hubs from a nackerd cv joint gaiter, all helps with the dirty hands we all like to show off to the laydees
Looking for £80 for the pair
Can post at a cost, these are heavy, looking at £20 postage via courier
