Spark Plugs
BobbyG
Spark Plugs
Post by BobbyG »
Getting a little juddery at low revs/speeds....gonna start with changing the plugs methinks.
Anything I need to know?? (particular type to go for etc)
Thanks in advance!
Trunkz
Re: Spark Plugs
Post by Trunkz »
According to my haynes manual, you need NGK ones. I've always got em off VW, comes to just under £3 per plug with the VAT if you get it through TPS. Before buying a new set of plugs, whip em out and check that they're okey. Also, check that the HT leads are firing correctly :)
Trottagti
Re: Spark Plugs
Post by Trottagti »
Iv just ordered a new dis pack for mine aswell, the part that distributes the spark to the plugs. Where your ht leads finish up.
If you pull your leads off and see a load of White powder in there I would change it...
