Which SHARK FIN?
KLAUD
Which SHARK FIN?
Post by KLAUD »
Is there one available, that would work as a straight swap?...plug and play with no need to modify the wiring connections?
blazeguarder
Re: Which SHARK FIN?
Post by blazeguarder »
The ebay ones usually have the proper connectors, so they are plug and play. Only problem to watch out for is that they usually don't have amplifiers whereas the stock one does so unless you have an aftermarket HU with an aerial amplifier installed then you might lose signal quality. They aren't that expensive and are quite easy to fit so best to give it a go and see. They are quite easy to sell on if they don't work properly.
KLAUD
Post by KLAUD »
I have an Alpine headunit and to be fair the radio receptions not that good anyway...may need an amplifier regardless
88rsr
Post by 88rsr »
you do lose signal big time, but i dont listen to the radio so its looks over performance for me :mrgreen:
