Can any1 help with a Media In cable on a 6R
VW Part Number - 000 051 446C
I got this part, which seems pretty easy to fit as it goes in the CD Changer/Media IN on the back of the headunit.
Has anyone else fitter one of these? where exactly did you access the lead? Glove box?... how did you get the cable into the glove box?
If anyone can help it would be much appreciated.
Their should be a socket in the top left of the glovebox that cable is for the mutlidevice interface it won't plug into the headunit directly your need this http://www.ebay.co.uk/itm/VW-SEAT-MDI-M ... _832wt_898 plugged into your headunit before you can use that cable
Re: Can any1 help with a Media In cable on a 6R
Thank you, atleast some1 knows what they are talking about. I knew the guy didn't have a clue about it and i did think it was stupidly cheap to add Ipod conectivity
