Tyres
- kristafari
Tyres
Ok i recently bought a set of Montreal II's so that im off of those damn Hubs.
they are 16" with 205/55 tyres the back go on without a problem though the front is a lil dodgy. (standard suspension atm, due to funds. as always)
which tyres does anyone advise and the profile what is it that you guys would put onto them?
Opinions welcomed
Chris [:
Opinions welcomed
Chris [:
Ladiesman_317
Re: Tyres
I wouldnt advise running 55's, as they are golf tyres. I ran them for about a week or so, and it makes the steering really heavy! and uncomfortable to drive, im sure there also alot of mechanical disadvantages if you continue to run them. vw recommends 205/45, but i run 195/45 as the tyre side profile is smaller. but if you want wider tyres, you could get 205/40.
Re: Tyres
for performance on standard suspension toyo t1r's hands down an awesome tyre! grips like no other street tyre only thing if you drive hard everywhere they literally melt away lol but a mix of driving and you should see 12,000 miles which isnt bad for the performance!
Re: Tyres
or if you really need grip r1r are good but last 9000 maxDub_Dan wrote:for performance on standard suspension toyo t1r's hands down an awesome tyre! grips like no other street tyre only thing if you drive hard everywhere they literally melt away lol but a mix of driving and you should see 12,000 miles which isnt bad for the performance!
- kristafari
Re: Tyres
Cheers guys, i might go with the 195/45/16 i like the flush look.
woud it really affect the speedo that much?
- kristafari
Re: Tyres
thanks ill give it a look once ive done my CW, what is it?
Re: Tyres
also check out here http://www.tyrestretch.com/ to see what the different size tyres will look likekristafari wrote:Cheers guys, i might go with the 195/45/16 i like the flush look.
- kristafari
Re: Tyres
does stretching affect the mileage of the tyre ?
- kristafari
Re: Tyres
may use these montys i have as winter wheels, anyone advise any specific tyres for the winter?
- kristafari
Re: Tyres
are they tyres specifically for winter?
Thanks, Chris [:
Thanks, Chris [:
