knocking noise
damager999
knocking noise
hi im new here and just got my first polo its a 95 6n, im getting a knock every time i go over a hump its the exhaust on the rear axle the cars lowered but could someone please tell me how to stop the exhasut knocking because its doin my head in
thanks.
Re: knocking noise
you probably need to check the exhaust hanging rubbers, you may have one broken, failing that, loosen all the joints, and twist the exhaust so it clears the rear beam, and then re tighten.
That may help.
good luck
That may help.
good luck
damager999
Re: knocking noise
thanks mate i will give it a try
