central convenience fuse?
Posted: Fri May 21, 2004 9:22 am
by mikegti
when you take the key out the ignition it should do two things:
the courtesy light should come on and also the radio should turn off ?
mine doesnt do this anymore :(
someone on ukmkiv's told me it was the central convenience fuse but I can't work out which one it is... anyone able to help?
cheers,
mike
Posted: Fri May 21, 2004 6:51 pm
by Josh_PoloGTi
This happened to me too...
But the dealer fixed it up (it took them MONTHS to sort it out).
I have the wiring diagrams somewhere (the technical specialist that finally fixed it gave them to me!!)... I'll have a look for them over the weekend and will let you know.
By the way, mine needed a new ignition-switch bottom (the switch bit) as well as a fuse.
Posted: Fri May 21, 2004 8:41 pm
by mikegti
cheers Josh, thosewould be a real help! was the switch expensive?
oh and while you're here ... have you got any uk-polos stickers left, inside ones ?
cheers,
mike
Posted: Wed Jun 15, 2005 10:42 am
by inder
sorry to bump this old post, Josh_PoloGTi do you still have the diagram?
