when you take the key out the ignition it should do two things:
the courtesy light should come on and also the radio should turn off ?
mine doesnt do this anymore
someone on ukmkiv's told me it was the central convenience fuse but I can't work out which one it is... anyone able to help?
But the dealer fixed it up (it took them MONTHS to sort it out).
I have the wiring diagrams somewhere (the technical specialist that finally fixed it gave them to me!!)... I'll have a look for them over the weekend and will let you know.
By the way, mine needed a new ignition-switch bottom (the switch bit) as well as a fuse.
