Exhaust Manifold
J-O
Exhaust Manifold
Hi!
As anyone here installed and aftermarket exhaust manifold?
If yes, is it worth getting this part, what gain did you get?
Finally, what compagnies makes these for Polo 1.4 16V (i know supersprint does)...
Benefits of a manifold depend very much on the car you're fitting it to. There should always be a gain from an after market manifold, unless it's badly made/designed. I've seen figures of 15bhp from manifolds, which frankly I find a little absurd although I've seen a 1400 gain 7bhp from one of our Sorg manifolds ~ usually I'd say you will do well with a 4-5bhp increase.
Sorg manifolds are staniless steel so should last for the time you have the car but unless you're really going to tune the engine etc I'd spend the money on alcohol and take aways
- Josh_PoloGTi
- Drives: BMW E85 Z4 3.0i
hardhitter
- Moderator
I've heard plenty of stories of golfs cracking the exhaust manifolds (especially stainless ones). Its a different car with different circumstances (so don't assume it's the same) for a start the manifold is at the back of the engine. Golfs need uprated engine mounts to stop it happening.
With a polo, providing the engine mounts are fine and you have a flexi on the exhuast it will be fine. It depends how restrictive your existing manifold is and what other mods you will be doing to say if it's worth having one or not.
GroovyCarrot
- Sponsor
Tahrey1043
Re: manifolds cracking under acceleration. That would explain why my exhaust manifold gasket keeps falling to bits every 9000 or so miles!
Re: restriction on mk2 air boxes.......... i havent any knowledge on that at all, but speculation wise - some GT/G40 mk3 boxes were apparently restricted (to keep it off the limiter so much), and so there's precedent for it. Plus a rev limiter wasn't standard mk2 equip, so something to knock the top-end power off is probably a smart idea even if it hurts the performance a little
Re: Exhaust Manifold
Szukałem niedawno czegoś z wyższej półki na podziękowanie dla ważnego klienta biznesowego i zależało mi, żeby nie był to zwykły trunek z supermarketu, tylko elegancka edycja w ozdobnym kartoniku lub tubie. Jeśli potrzebujecie rzadszych wydań single malt, dojrzałego koniaku czy francuskiego szampana z renomowanego domu winiarskiego, to ten luksusowe alkohole sklep https://finespirits.pl/pl/ sprawdza się idealnie. Paczkę spakowali pancernie, butelka w nienaruszonym stanie dotarła w dwa dni, a sam wybór trunków kolekcjonerskich robi wrażenie.
