polo gti engine cooling fan and aircon
rover220
Post by rover220 »
seeing the other similar thread got me thinking, my fan only ever runs at full speed when the car is starting to get very warm.
it never runs slowly and never runs when the aircon compressor is on unless the engine is getting hot.
its my understanding that with the compressor running the fan should be running too, is this correct?
do i need a new fan or is it something more serious?
cheers
Re: polo gti engine cooling fan and aircon
Your fan resistor is shot - you need a new fan so that you can run a slow speed fan again.
rover220
Post by rover220 »
alexperkins wrote:Your fan resistor is shot - you need a new fan so that you can run a slow speed fan again.
so this isnt an ecu fault (im use to rover systems which work differently) and a new fan will definately fix this?
cheers
Not an ECU fault and a new fan will fix it - i had this problem about 2 weeks back on a clients GTI
rover220
Post by rover220 »
alexperkins wrote:Not an ECU fault and a new fan will fix it - i had this problem about 2 weeks back on a clients GTI
Wonderful, you don't happen to know how much a new one is off the top of your head do you?
About £150 from the dealer
Recommend you find a working used one.
rover220
Post by rover220 »
alexperkins wrote:About £150 from the dealer
Ouch
Is there a test that can be done to check if it's working with the use of a multimeter?
Check the resistance between the earth (brown) and the two other contacts
You'll need to set the multimeter to its highest ohm setting, and if broken, one of the contacts when tested should show a 1 instead of 0.something which will confirm a break in the circuit
rover220
Post by rover220 »
alexperkins wrote:Check the resistance between the earth (brown) and the two other contacts
Brilliant, thankyou
WSMRT18
Post by WSMRT18 »
Did this solve your problem? My climate control doesnt work and I have never heard the compressor or had a slow running fan, could need a regas aswell maybe? Thanks
rover220
Post by rover220 »
Yep. New fan sorted mine.
If you're compressor doesn't kick in then you have a fault other than the fan. Most likely need a regass.
TriggerFish
Location: Aylesbury, Bucks Drives: Polo GTi, 330d 'M-Sport'
Post by TriggerFish »
When this happens on golfs, they just solder in a couple of new resistors - would that be possible on the Polo? Would save about £145...
rover220
Post by rover220 »
TriggerFish wrote:When this happens on golfs, they just solder in a couple of new resistors - would that be possible on the Polo? Would save about £145...
almost certainly could be done yeah
TriggerFish
Not on my phone now so can post links easily.
If it helps there's this: http://uk-mkivs.net/forums/p/59897/449470.aspx#449470
And more importantly this: http://website.lineone.net/~alan.james. ... epair.html
Not sure if the Polo fans are the same, but could be something to look into anyway!
WSMRT18
Post by WSMRT18 »
Ok guys thanks for your responses I will look into it,
Sorry if this is a stupid question dont really know much about air con, if theres no gas in the system the compressor wont kick in? I dont want to spend money regassing it then find I have a shot compressor.
Thanks for your help really apreciate it
