Page 1 of 2
polo gti engine cooling fan and aircon
Posted: Tue Nov 08, 2011 11:58 am
by rover220
seeing the other similar thread got me thinking, my fan only ever runs at full speed when the car is starting to get very warm.
it never runs slowly and never runs when the aircon compressor is on unless the engine is getting hot.
its my understanding that with the compressor running the fan should be running too, is this correct?
do i need a new fan or is it something more serious?
cheers
Re: polo gti engine cooling fan and aircon
Posted: Tue Nov 08, 2011 1:48 pm
by alexperkins
Your fan resistor is shot - you need a new fan so that you can run a slow speed fan again.
Posted: Tue Nov 08, 2011 2:46 pm
by rover220
alexperkins wrote:Your fan resistor is shot - you need a new fan so that you can run a slow speed fan again.
so this isnt an ecu fault (im use to rover systems which work differently) and a new fan will definately fix this?
cheers
Posted: Tue Nov 08, 2011 3:05 pm
by alexperkins
Not an ECU fault and a new fan will fix it - i had this problem about 2 weeks back on a clients GTI
Posted: Tue Nov 08, 2011 3:21 pm
by rover220
alexperkins wrote:Not an ECU fault and a new fan will fix it - i had this problem about 2 weeks back on a clients GTI
Wonderful, you don't happen to know how much a new one is off the top of your head do you?
Posted: Tue Nov 08, 2011 3:23 pm
by alexperkins
About £150 from the dealer
Recommend you find a working used one.
Posted: Tue Nov 08, 2011 3:32 pm
by rover220
alexperkins wrote:About £150 from the dealer
Ouch
Is there a test that can be done to check if it's working with the use of a multimeter?
Posted: Tue Nov 08, 2011 3:38 pm
by alexperkins
Check the resistance between the earth (brown) and the two other contacts
You'll need to set the multimeter to its highest ohm setting, and if broken, one of the contacts when tested should show a 1 instead of 0.something which will confirm a break in the circuit
Posted: Tue Nov 08, 2011 3:47 pm
by rover220
alexperkins wrote:Check the resistance between the earth (brown) and the two other contacts
Brilliant, thankyou
Posted: Thu May 24, 2012 10:53 pm
by WSMRT18
Did this solve your problem? My climate control doesnt work and I have never heard the compressor or had a slow running fan, could need a regas aswell maybe? Thanks
Posted: Fri May 25, 2012 6:18 am
by rover220
Yep. New fan sorted mine.
If you're compressor doesn't kick in then you have a fault other than the fan. Most likely need a regass.
Posted: Fri May 25, 2012 7:53 am
by TriggerFish
When this happens on golfs, they just solder in a couple of new resistors - would that be possible on the Polo? Would save about £145...
Posted: Fri May 25, 2012 8:34 am
by rover220
TriggerFish wrote:When this happens on golfs, they just solder in a couple of new resistors - would that be possible on the Polo? Would save about £145...
almost certainly could be done yeah
Posted: Fri May 25, 2012 9:28 am
by TriggerFish
Not on my phone now so can post links easily.
If it helps there's this:
http://uk-mkivs.net/forums/p/59897/449470.aspx#449470
And more importantly this:
http://website.lineone.net/~alan.james. ... epair.html
Not sure if the Polo fans are the same, but could be something to look into anyway!
Posted: Wed May 30, 2012 11:52 am
by WSMRT18
Ok guys thanks for your responses I will look into it,
Sorry if this is a stupid question dont really know much about air con, if theres no gas in the system the compressor wont kick in? I dont want to spend money regassing it then find I have a shot compressor.
Thanks for your help really apreciate it
