Polo 9N3 Wheel Alignment/Tracking Camber Issues
Hi just wanted to know whether anyone else has had this same problem and if there is a solution to it. Basically I had lowered my car on JOM coilovers but there not wound all the way down. I went to do my tracking and the garage was able to alter the toe so that's perfectly fine now its just the camber on the front end and the camber on the rear left end that is still out, even after going to do a wheel alignment. The left front side is -1°07' , the right front is -1°02' , and the rear left is -1°19' , the rear right camber is fine being -1°34'. So im just wondering is there a way that I could possibly get it more or less even on the cambers that are out and what the problem could be? I've been told that I could use the eibach alignment camber bolts for the front and shims for the back to get them more or less right would this work or would i need to do something else?
