Everything else is fine (i.e using the key manually to open all doors and using the ignition)
Changed the wee battery but nothing works, even the bulb doesnt light up when pressing the button..
I've taken some pictures of the inside of the mechanism incase anyone has any ideas on what the problem might be and how i can fix it.
Heres basically all the parts that came out of it -
this one with everything out of it (the part in at the left hand side which looks like a glass sensor or something appears to be smashed?) i cant remove it and i dont know what that part is -
Took this one as well with the spring in place (minus the battery and bulb) incase something is missing that someone could point out?
