1 - 5A - Control unit in dash panel insert
ABS control unit
Mobile telephone operating electronics control unit
2 - 10A - Steering column combination switch
Onboard supply control unit
Rear window wiper motor
Windscreen and rear window washer pump
3 - 5A - Fuel pump relay
Engine control unit
Fuel supply relay
Fuel pump control unit
Control unit for structure-borne sound
4 - 2A - Steering column combination switch
5 - - Reserve
6 - 5A - Control unit in dash panel insert
7 - 5A - Headlight range control regulator
Number plate left light
Number plate right light
8 - 10A - Injector, cylinder 1
Injector, cylinder 2
Injector, cylinder 3
Injector, cylinder 4
Lambda probe heater
Lambda probe 1 heater after catalytic converter
Activated charcoal filter system solenoid valve 1
9 - 5A - TCS and ESP button
or 7.5A Tyre pressure monitor display button
Steering angle sender
ABS control unit
Stop/start system button
Data bus diagnostic interface
10 - 5A - Cruise control system switch
Brake light switch
Clutch pedal switch
11 - 10A - Headlight range control regulator
or 5A Left headlight range control motor
Right headlight range control motor
Cornering light and headlight range control unit
12 - 5A - Mirror adjustment switch
13 - 5A - Mechatronic unit for dual clutch gearbox
Selector lever
14 - 5A - Airbag control unit
Front passenger side airbag deactivated warning lamp
15 - 5A - Left washer jet heater element
Right washer jet heater element
16 - 5A - Parking aid control unit
17 - - Reserve
18 - 5A - Rear fog light cut-out contact switch
Rear left fog light bulb -L46-Onboard supply control unit
19 - 5A - Onboard supply control unit
20 - 5A - Steering angle sender
Fuel supply relay
Terminal 30 voltage supply relay
Low heat output relay
High heat output relay
21 - 10A - Onboard supply control unit
22 - 5A - Diagnostic connection
Climatronic control unit
Air conditioning system control unit
Ignition key withdrawal lock solenoid
23 - 5A - Selector lever
Rain sensor
Engine control unit
24 - 5A - Onboard supply control unit
Driver side heated exterior mirror
Front passenger side heated exterior mirror
25 - 5A - High pressure sender
Heater control unit
Radiator fan control unit
Trailer detector control unit
Humidity sender
Voltage stabiliser
Voltage stabiliser 2
26 - 7.5A- Air mass meter
Oil level and oil temperature sender
Power steering control unit
Heater element for crankcase breather
Starter relay 1
Starter relay 2
27 - 7.5A- Reversing light switch
28 - 10A - Lambda probe
Lambda probe after catalytic converter
Lambda probe heater
29 - 10A - Fuel pressure regulating valve
Fuel metering valve
30 - 10A - Charge pressure control solenoid valve
Exhaust gas recirculation cooler change-over valve
Coolant circulation pump 2 -V178-Heater element relay
31 - 10A - Sender for gas gauge
or 5A Automatic glow period control unit
Fuel supply relay
Additional coolant pump relay
32 - 10A - Fuel gauge sender
or 15A Fuel system pressurisation pump
or 20A Engine control unit
or 30A
33 - 5A - Clutch position sender
Brake light switch
34 - 15A - Control unit in dash panel insert
Left main beam bulb
Right main beam bulb
Left gas discharge light control unit
Right gas discharge light control unit
35 - 15A - Engine control unit
or 20A Fuel supply relay
36 - 7.5A- Right main beam bulb
37 - 25A - Heated driver seat regulator
Heated front passenger seat regulator
Heated front seats control unit
38 - 30A - Mechatronic unit for dual clutch gearbox
39 - 10A - Right dipped beam bulb
or 15A
40 - 30A - Fresh air blower switch
Fresh air blower control unit
41 - 10A - Rear window wiper motor
42 - 15A - Cigarette lighter
12 V socket
43 - 15A - Onboard supply control unit
44 - 5A - Anti-theft alarm ultrasonic sensor
Alarm horn
45 - 15A - Control unit with display for radio and navigation system
Multimedia control unit
Radio
Voltage stabiliser
46 - 20A - Headlight washer system relay
47 - 20A - Onboard supply control unit
Windscreen wiper motor
48 - 25A - Onboard supply control unit
49 - 30A - Sliding sunroof adjustment control unit
49 - 15A - Fuel pump relay
Fuel supply relay
50 - 25A - Driver door control unit
51 - 25A - Front passenger door control unit
52 - 30A - Rear left door control unit
Rear right door control unit
53 - 30A - Onboard supply control unit
54 - 15A - Left fog light bulb
Right fog light bulb
55 - 15A - Ignition coil 1 with output stage
or 20A Ignition coil 2 with output stage
Ignition coil 3 with output stage
Ignition coil 4 with output stage
56 - 15A - Left day driving light bulb
Right day driving light bulb
57 - 15A - Onboard supply control unit
58 - 20A - Brake servo vacuum pump
59 - 10A - Left dipped beam bulb
or 15A
60 - 15A - Control unit with display for radio and navigation system
shame all this effort including trying to translate it from german im still none the wiser to why my 12v socket doesnt work
I had this in my old Polo, my socket wouldn't work so I immediatley thought the fuse had blown. Changed the fuse and it still didn't work, I mentioned it on the service and they replaced the unit free of charge
id hope so under warranty lol
Yeah, but I would have thought they would have tried to squirm out of replacing it for free, under the old, "wear and tear" line
Thanks AJ_7 for posting this, it saved me from posting this info in this forum.
As I posted the info in ClubPolo, I wish to add the proviso that the fuse layout is for a 2011 model GTI, I presume the layout is similar for other 6R Polo's.
Can anyone tell me which fuse is for the windscreen washers? Can't seem to see it Anyway they stopped working last week but the headlight washers still work!
stuart.cameron wrote:Can anyone tell me which fuse is for the windscreen washers? Can't seem to see it Anyway they stopped working last week but the headlight washers still work!
Theirs a chance that using non vw screenwash clogs the fan jets flush normal water though the list says 2
Yeah was hoping it wouldn't be that. That fuse is fine (Don't know how I missed it on the list). Only thing is I can't remember putting screen wash in it, I normally just fill it from the hose when washing the car. Dealer says they will replace the jets once under warranty...
