UK-POLOS.NET - THE VW Polo Forum • fuse guide
fuse guide
Posted: Sun Jan 22, 2012 2:24 pm
by daydotz
im looking for the fuse guide for my polo does anyone have it ?
ive found them on clubpolo but im stilling waiting for my account to be validated :( can anyone grab the image and text for me ?
http://www.clubpolo.co.uk/forum/index.p ... &p=2248914
thanks
Re: fuse guide
Posted: Sun Jan 22, 2012 5:31 pm
by AJ_7
1 - 5A - Control unit in dash panel insert
ABS control unit
Mobile telephone operating electronics control unit
2 - 10A - Steering column combination switch
Onboard supply control unit
Rear window wiper motor
Windscreen and rear window washer pump
3 - 5A - Fuel pump relay
Engine control unit
Fuel supply relay
Fuel pump control unit
Control unit for structure-borne sound
4 - 2A - Steering column combination switch
5 - - Reserve
6 - 5A - Control unit in dash panel insert
7 - 5A - Headlight range control regulator
Number plate left light
Number plate right light
8 - 10A - Injector, cylinder 1
Injector, cylinder 2
Injector, cylinder 3
Injector, cylinder 4
Lambda probe heater
Lambda probe 1 heater after catalytic converter
Activated charcoal filter system solenoid valve 1
9 - 5A - TCS and ESP button
or 7.5A Tyre pressure monitor display button
Steering angle sender
ABS control unit
Stop/start system button
Data bus diagnostic interface
10 - 5A - Cruise control system switch
Brake light switch
Clutch pedal switch
11 - 10A - Headlight range control regulator
or 5A Left headlight range control motor
Right headlight range control motor
Cornering light and headlight range control unit
12 - 5A - Mirror adjustment switch
13 - 5A - Mechatronic unit for dual clutch gearbox
Selector lever
14 - 5A - Airbag control unit
Front passenger side airbag deactivated warning lamp
15 - 5A - Left washer jet heater element
Right washer jet heater element
16 - 5A - Parking aid control unit
17 - - Reserve
18 - 5A - Rear fog light cut-out contact switch
Rear left fog light bulb -L46-Onboard supply control unit
19 - 5A - Onboard supply control unit
20 - 5A - Steering angle sender
Fuel supply relay
Terminal 30 voltage supply relay
Low heat output relay
High heat output relay
21 - 10A - Onboard supply control unit
22 - 5A - Diagnostic connection
Climatronic control unit
Air conditioning system control unit
Ignition key withdrawal lock solenoid
23 - 5A - Selector lever
Rain sensor
Engine control unit
24 - 5A - Onboard supply control unit
Driver side heated exterior mirror
Front passenger side heated exterior mirror
25 - 5A - High pressure sender
Heater control unit
Radiator fan control unit
Trailer detector control unit
Humidity sender
Voltage stabiliser
Voltage stabiliser 2
26 - 7.5A- Air mass meter
Oil level and oil temperature sender
Power steering control unit
Heater element for crankcase breather
Starter relay 1
Starter relay 2
27 - 7.5A- Reversing light switch
28 - 10A - Lambda probe
Lambda probe after catalytic converter
Lambda probe heater
29 - 10A - Fuel pressure regulating valve
Fuel metering valve
30 - 10A - Charge pressure control solenoid valve
Exhaust gas recirculation cooler change-over valve
Coolant circulation pump 2 -V178-Heater element relay
31 - 10A - Sender for gas gauge
or 5A Automatic glow period control unit
Fuel supply relay
Additional coolant pump relay
32 - 10A - Fuel gauge sender
or 15A Fuel system pressurisation pump
or 20A Engine control unit
or 30A
33 - 5A - Clutch position sender
Brake light switch
34 - 15A - Control unit in dash panel insert
Left main beam bulb
Right main beam bulb
Left gas discharge light control unit
Right gas discharge light control unit
35 - 15A - Engine control unit
or 20A Fuel supply relay
36 - 7.5A- Right main beam bulb
37 - 25A - Heated driver seat regulator
Heated front passenger seat regulator
Heated front seats control unit
38 - 30A - Mechatronic unit for dual clutch gearbox
39 - 10A - Right dipped beam bulb
or 15A
40 - 30A - Fresh air blower switch
Fresh air blower control unit
41 - 10A - Rear window wiper motor
42 - 15A - Cigarette lighter
12 V socket
43 - 15A - Onboard supply control unit
44 - 5A - Anti-theft alarm ultrasonic sensor
Alarm horn
45 - 15A - Control unit with display for radio and navigation system
Multimedia control unit
Radio
Voltage stabiliser
46 - 20A - Headlight washer system relay
47 - 20A - Onboard supply control unit
Windscreen wiper motor
48 - 25A - Onboard supply control unit
49 - 30A - Sliding sunroof adjustment control unit
49 - 15A - Fuel pump relay
Fuel supply relay
50 - 25A - Driver door control unit
51 - 25A - Front passenger door control unit
52 - 30A - Rear left door control unit
Rear right door control unit
53 - 30A - Onboard supply control unit
54 - 15A - Left fog light bulb
Right fog light bulb
55 - 15A - Ignition coil 1 with output stage
or 20A Ignition coil 2 with output stage
Ignition coil 3 with output stage
Ignition coil 4 with output stage
56 - 15A - Left day driving light bulb
Right day driving light bulb
57 - 15A - Onboard supply control unit
58 - 20A - Brake servo vacuum pump
59 - 10A - Left dipped beam bulb
or 15A
60 - 15A - Control unit with display for radio and navigation system
Re: fuse guide
Posted: Sun Jan 22, 2012 5:33 pm
by AJ_7
Re: fuse guide
Posted: Sun Jan 22, 2012 6:09 pm
by daydotz
i could kiss you thanks :D
shame all this effort including trying to translate it from german im still none the wiser to why my 12v socket doesnt work :cry:
Re: fuse guide
Posted: Sun Jan 22, 2012 6:13 pm
by AJ_7
daydotz wrote:i could kiss you thanks :D
I had this in my old Polo, my socket wouldn't work so I immediatley thought the fuse had blown. Changed the fuse and it still didn't work, I mentioned it on the service and they replaced the unit free of charge :)
Re: fuse guide
Posted: Sun Jan 22, 2012 6:39 pm
by daydotz
id hope so under warranty lol
Re: fuse guide
Posted: Sun Jan 22, 2012 6:41 pm
by AJ_7
Yeah, but I would have thought they would have tried to squirm out of replacing it for free, under the old, "wear and tear" line :)
Re: fuse guide
Posted: Sun Jan 22, 2012 8:45 pm
by foggy69
Thanks AJ_7 for posting this, it saved me from posting this info in this forum.
As I posted the info in ClubPolo, I wish to add the proviso that the fuse layout is for a 2011 model GTI, I presume the layout is similar for other 6R Polo's.
fuse guide
Posted: Mon Jan 23, 2012 7:27 pm
by stuart.cameron
Can anyone tell me which fuse is for the windscreen washers? Can't seem to see it :( Anyway they stopped working last week but the headlight washers still work!
fuse guide
Posted: Mon Jan 23, 2012 8:06 pm
by daydotz
stuart.cameron wrote:Can anyone tell me which fuse is for the windscreen washers? Can't seem to see it :( Anyway they stopped working last week but the headlight washers still work!
Theirs a chance that using non vw screenwash clogs the fan jets flush normal water though the list says 2
fuse guide
Posted: Mon Jan 23, 2012 10:35 pm
by stuart.cameron
Yeah was hoping it wouldn't be that. That fuse is fine (Don't know how I missed it on the list). Only thing is I can't remember putting screen wash in it, I normally just fill it from the hose when washing the car. Dealer says they will replace the jets once under warranty...
Re: fuse guide
Posted: Tue Jan 24, 2012 4:54 pm
by daydotz
ive had two requests for an account rejected at clubpolo :roll:
oh well turns out it was broken
fuse guide
Posted: Tue Jan 24, 2012 5:26 pm
by benmkiv
Don't worry bud not missing much ;)
