There's a black ring thing that holds the bulb in place in the projector. I'm not sure if it twists off or pulls off. Whichever it is it's damn tight and ultimately is how I ended up breaking the adjuster on the drivers side (trying to force it back on).
Few other tips, on the drivers side you'll need to remove the air feed.
Passenger side you'll need to move/remove the battery.
Also, don't try to remove them with the black headlight cover still on the back of the unit. It's just too fiddly!
