Calliper Clearance and Upgrading Discs
I have clearing issues with my front callipers. Spacers is the easy opinion but thought about a big brake discs so the calliper sits further away from the centre bore. I have no idea if im way off with this idea. Any suggestions would be great thanks.
I had this problem. Spacers are the easiest an cheapest option. Input mine out 3mm just to clear the calliper. Have you just changed the pads and discs? Mine were like this but then once bedded in I could take the spacers off if I wanted its all to do wih how the floating calliper works.
