Bulb monitoring light?
- jamesagordon
(also my traction control and ABS light after fitting coilies)
So I bought some 501 LEDs to swap for my standard interior bulbs and I was having a few issues, some were working and then some weren't, anyway after fiddling about for a bit i turned my electrics on and my bulb monitoring warning light came up on the dash and there was a weird ticking noise coming from the dash too. I turned the electrics off and swapped back to my standard bulbs and its still doing it and now none of the interior lights work.
Anyone know how to fix this please?
Can I just reset my ECU, if so how without VAGCOM?
- NeilMcConville
Re: Bulb monitoring light?
Think you've blown a fuse mate!
- jamesagordon
damn my rear interior lights won't work either
It's just a fuse, I did the same then left it, im the drivers footwell you'll see a flap, undo it and locate fuse 21 iirc and replace that and just leave it lol it'll sort all them problems, the coilie lights sound weird though :S mine are all fine no lights.
- jamesagordon
cheers mate, will the new bulbs work if i put them in the replace the fuse or do you reckon it'll blow it again?
Yeah it's weird, gonna try and reset my ECU, if that fails need to find a mate with VAG COM
- Boyracer_2011
- Drives: 1.2 Moda
Same happened to mine mate, manage to change the fuse and my new interior lights work fine
Heres what I did
http://uk-polos.net/viewtopi ... 56&t=56111
Heres what I did
- jamesagordon
cheers mate, which fuse is it and what kind of fuse do i need?
- Boyracer_2011
- Drives: 1.2 Moda
Its the little fuses on the right handside mate, it is the third one along on the top row. Red 10 amp. I tryed to change my boot light and that how I popped mine lol
Let me know how you get on.
- Boyracer_2011
- Drives: 1.2 Moda
This was the fuse what popped on mine...
Hope this helps!
- jamesagordon
I've ordered a new one but I took this one out and I still have this ticking noise coming from my dash!
- jamesagordon
someone help me this sound is making me sad
- Boyracer_2011
- Drives: 1.2 Moda
You may need to put a new one in to stop the ticking mate, I had to put up with it for four days I was ready to top myself lol.
- jamesagordon
It's so annoying! I'll try it when I get the car back. The dent that dosey woman put in the side of my car is being repaired, apparently the garage need it for 8 days?! I've got a newer bigger engined polo as a replacement but I'm missing mine already!
