I am new here, Hello hello!!
I was just wondering about my 1.2 Polo 9n e 55 if it has heated wing mirror, There is a little sign on the little switch that moves the wing mirrors however i dont know how to turn it on
Personaly, I'd prove that point before thinking that its fact, I have a very late 2000MY Passat B5 and only found out how VW controlled these heater on a VW forum, unfortunately too late for my heaters so I had to buy new mirror glasses. Wife has a 2003MY Polo and I've always made a point of advising her to do as I do with the Passat. I think that the actual facts are missing from the operator's manual. These mirror heaters are very handy in cold wintery weather as I tend to drive to work through "colder" and "warmer" areas so the mirrors fog up frequently. One thing to bear in mind, if you think that you can check the heaters for good/bad using a DMM, then remember that a very low resistance = "good" conversaly, a very high resistance = "bad". Actual tapes burn out but the high measured resistance is just the backing material which has carbonised quite a bit.Bickerton wrote:Pretty sure they only heat up when you turn the rear screen heater on an then its onl for a few minutes
