Heated Wing Mirrors
Posted: Wed May 16, 2012 12:58 pm
by KumiSinghs
Hi All,
I am new here, Hello hello!!
I was just wondering about my 1.2 Polo 9n e 55 if it has heated wing mirror, There is a little sign on the little switch that moves the wing mirrors however i dont know how to turn it on :(
Re: Heated Wing Mirrors
Posted: Thu May 17, 2012 10:10 pm
by 88rsr
Put it to the central position between L&R on the adjuster switch I think?
Posted: Fri May 25, 2012 2:42 pm
by KumiSinghs
It normally is on the center position, however when i touch the mirrors they do not feel warm or hot?
Posted: Fri May 25, 2012 11:02 pm
by RUM4MO
Try to remember to switch them off as soon as the mirrors have cleared as the heaters will burn out if left on especially in warmer weather.
Posted: Sat May 26, 2012 6:31 am
by Bickerton
Pretty sure they only heat up when you turn the rear screen heater on an then its onl for a few minutes
Posted: Sat May 26, 2012 1:37 pm
by RUM4MO
Bickerton wrote:Pretty sure they only heat up when you turn the rear screen heater on an then its onl for a few minutes
Personaly, I'd prove that point before thinking that its fact, I have a very late 2000MY Passat B5 and only found out how VW controlled these heater on a VW forum, unfortunately too late for my heaters so I had to buy new mirror glasses. Wife has a 2003MY Polo and I've always made a point of advising her to do as I do with the Passat. I think that the actual facts are missing from the operator's manual. These mirror heaters are very handy in cold wintery weather as I tend to drive to work through "colder" and "warmer" areas so the mirrors fog up frequently. One thing to bear in mind, if you think that you can check the heaters for good/bad using a DMM, then remember that a very low resistance = "good" conversaly, a very high resistance = "bad". Actual tapes burn out but the high measured resistance is just the backing material which has carbonised quite a bit.
BTW, your statement is correct as far as VX is/was concerned - and that way of controlling them makes sense, which will be the very reason why I burned my Passat ones out!
Posted: Sat May 26, 2012 2:26 pm
by Bickerton
From the handbook, seems I remembered it half right when I saw it in the past.
