Coming home lights - special technique?
joeallenpro
I've read in a few places that the Polo 6R has a special technique for activating coming home lights...
People have said if you flash the full beam after removing the key from the ignition, the fog lights will illuminate until 15 seconds after the car has been locked,
I've read it in a few places with people confirming, but I cannot get it to work in my car!!!
Anyone else able to do this?
- Boyracer_2011
- Drives: 1.2 Moda
Re: Coming home lights - special technique?
Nope...just tryed it, Dosnt work on mine mate. It would be cool to have tho
x2Boyracer_2011 wrote:Nope...just tryed it, Dosnt work on mine mate. It would be cool to have tho
x3Boyracer_2011 wrote:Nope...just tryed it, Dosnt work on mine mate. It would be cool to have tho
- stuart.cameron
x4Boyracer_2011 wrote:Nope...just tryed it, Dosnt work on mine mate. It would be cool to have tho
But I did read this somewhere else...
Just had a look on good old you tube cool feature, looks like it is either software change.
I had to use a VAGCOM cable to make the changes to get this to work.
- Boyracer_2011
- Drives: 1.2 Moda
Nice1 mate, so it can be done then... Would the vw garage do this coz I havnt got Vagcom.
To get the automatic "coming home" lights working, you need to have a specific harness that you install and then code in.
KieranLeighton
Need a harness.
http://www.kufatec.co.uk/shop/product_i ... info/p9235
then a new light switch, And xenon head lights, And rain sensor
and if you haven't got it
your gonna be looking at about 3k, as the xenon head lights retrofit kit they do his £2,217
http://www.kufatec.co.uk/shop/product_i ... lo-6R.html
for me i can justify spending 2k on a set of lights, no matter how bright there are
- stuart.cameron
This now works with my car. Flash the headlights after removing the key and then when you open the door the DRL's and cornering lights illuminate for 15 seconds.
Don't know how it didn't work before....
Sounds like its a software update hasn't your car been into vw recently ?stuart.cameron wrote:This now works with my car. Flash the headlights after removing the key and then when you open the door the DRL's and cornering lights illuminate for 15 seconds.
By cornering light you mean the one. In the headlight
Do you have vcds ?
- stuart.cameron
Yeah the car was in earlier last month. Only found out it worked by accident the other day.daydotz wrote:Sounds like its a software update hasn't your car been into vw recently ?stuart.cameron wrote:This now works with my car. Flash the headlights after removing the key and then when you open the door the DRL's and cornering lights illuminate for 15 seconds.
Do you have vcds ?
The two halogen lights in the headlight and DRLs illuminate also the taillights and number plate lights.
cool will have a go on mine in a bit
Golemsmate
Just tried on my 1.4 match but nothing happened!
that feature would of been amazing!
