What holds . . . .
dantheram
What holds . . . .
Post by dantheram »
the door card to the actual door, specifically, in the top left corner and along the top edge (the bit under the window from the door lock pin to the wing mirror).
i have 2 black square holes in the door and 2 circle shaped protrusions on the door card, how does it grip?
thanks,
Dan
P mk4
Re: What holds . . . .
Post by P mk4 »
Its like a popper you can pull the whole door card off there is one small fluffy bolt which goes in by the wing mirror. If they wont pop on easy make sure they are lined up and give it a fair hit with yourhand and should pop on :D
Hope this helps
dantheram
Post by dantheram »
i have the door apart just wondered how the hell it was attached in that top left corner with just the square hole thing and the circle thing on the door card :?:
dantheram
Post by dantheram »
My mistake i was looking at the wrong part of the door.
its on the bit closest to the rear quarter, on the vertical part. i have 2 tube shaped bits which only loosely attach to the door card, these then clip on to the standard 2 part black clips (the ones from the actual door through the membrane) but they are really loose in the door card seating - can i glue these in to the door card?
