Retrofit - MDI -RCD310 - Polo GTI - Help needed please.
fletcherk
Post by fletcherk »
Hi All,
I am sure that this has been asked a lot.
I am just asking for advice from someone who has done this themselves.
Which part was used and how difficult was it to setup.
I have some kits available fro websites and would like some advice as to the best kit.
Please do not say, "Go to your delearship". They are super confused and did not even know this is an option, I had to show them :(
Please help.
GuntherVW6R
Re: Retrofit - MDI -RCD310 - Polo GTI - Help needed please.
Post by GuntherVW6R »
I have retrofitted both the MDI and the RCD310 into my Polo.
The RCD310 was easy. All I had to do was remove the surround unscrew the screws around the side of the radio and it popped out once you unplug everything.
The MDI was a bit more difficult. I bought one that fitted in the glove box. I took off the glove box door and the whole frame of the glove box. Made a harness for the MDI to sit in to the frame of the glove box. There is a blank in that frame where the MDI port would show through. I just popped that off and then lined up the port to the hole and then screwed the mdi and harness to the frame of the glovebox. I then sent all the wiring round the side of the glove box in behind the radio and connected all the wires together. Put the Radio back in and the screw all the glovebox back together and it's sorted :)
Fitting the MDI does take a while but it is worth it :)
Sorry if my instructions are vague or unclear!
fletcherk
Post by fletcherk »
Did you need to do any coding to get the MDI working?
Which kit did you use?
Now I am VERY keen.
GuntherVW6R
I bought one like this off of eBay:
http://www.ebay.co.uk/itm/VW-MEDIA-IN-I ... 749wt_1156
Mine didn't require coding but I believe mine had been pulled out of another VW so you may need to code it depending on whether you buy and unused MDI or a used one :)
