Hey guys,
Have only just really got my 1.8t polo gti and was thinking of giving it a full service, what spark plugs would people recommend? NGK?
Any advice would be good
Chris
what spark plugs?
Re: what spark plugs?
If the car is stock, just go for the ones from VAG dealer.
If the car is tuned go for the S2 plugs also from VAG dealer so they run colder.
Original parts is always original.
Factory fitted Plugs are ngk pfr6q. These can be had cheaper than dealers from standard motor factors. They are exactly the same plug just without the vw logo.
If you are mapped, go a stage cooler and fit ngk pfr7q.
chrisa_gti
Thanks guys,
The car is standard for now with the plan to map it soon...will the car be ok running the cooler s2 spark plugs if its standard??
Can´t answer that one but on the contrary you can get the serial number for them!
101000016AA S2 spark plugs.
and the N75-J model is 034906283J from S2 also. Incase you want it later on!
