Any tips appreciated.
Removing Instrument Cluster
One word: How?
Remove one torque screw from the centre under cluster visor.
Then grab the rear of the visor closest to the windscreen and pull towards the rear of the car, you must pull hard to release it, it will unclip but it is hard work, once the visor is off the other torque screws are easy to spot, take care when removing the two plugs on the back of the cluster they have a clip that you have to lift up at one end and fold 180 degrees to remove the plugs, the mileage will remain the same once you reconnect the plugs.
What is wrong with yours.
John
John
