Hi guys,
Was casually drivin on the way to work, everything was fine until about 5mins into my journey my car kicks out 2 major splutter (similar to a fuel cut)...as i carried on my journey i have no power and max revs is limited to 5k. Anyone in the north/eastry london area have a vcds i can borrow for pint money or experienced something similar?!
thanks,
Ant
limp mode
Re: limp mode
Thats likely to be the camshaft timing sensor. Its to the right under the engine cover
Common failure - about £40 to replace.
Re: limp mode
Thanks Alex, I believe i got a similar error code when i scanned the car before but couldn't remember if it was the same part name.
Re: limp mode
Thankfully, it just unplugs and is only one allen bolt to remove it
emma_88
- Drives: 6N2 Polo GTi & 9N3 Polo GTi
Re: limp mode
Sounds identical to what happened to mine a few years back.
New camshaft sensor sorted it out
