limp mode
Posted: Tue Nov 06, 2012 10:08 am
by Ant168
Hi guys,
Was casually drivin on the way to work, everything was fine until about 5mins into my journey my car kicks out 2 major splutter (similar to a fuel cut)...as i carried on my journey i have no power and max revs is limited to 5k. Anyone in the north/eastry london area have a vcds i can borrow for pint money or experienced something similar?!
thanks,
Ant
Re: limp mode
Posted: Tue Nov 06, 2012 12:07 pm
by alexperkins
Thats likely to be the camshaft timing sensor. Its to the right under the engine cover
Common failure - about £40 to replace.
Re: limp mode
Posted: Tue Nov 06, 2012 12:14 pm
by Ant168
Thanks Alex, I believe i got a similar error code when i scanned the car before but couldn't remember if it was the same part name.
Re: limp mode
Posted: Tue Nov 06, 2012 12:17 pm
by alexperkins
Thankfully, it just unplugs and is only one allen bolt to remove it :)
Re: limp mode
Posted: Tue Nov 06, 2012 3:50 pm
by emma_88
Sounds identical to what happened to mine a few years back.
New camshaft sensor sorted it out :)
