Just putting feelers out at the moment as I know a few of you have expressed an interest in me doing another 3M GB...
Products available will be (as last time):
3M Perfect It III Cleaner Clay
(You get a big piece of high-quality clay in a sealable tub)
3M Perfect It III Fine Compound (1kg)
(Removes swirl marks and fine to medium scratches - Surface needs to be Glazed after use)
3M Imperial Hand Glaze (1 litre)
(Gives a glass-like finish to your paint, ready for waxing with a high quality wax such as Zymol, Swissol etc, however the wax is just for protecting the paint... The shine comes from the Glaze)
Last time I ran this I had 27 Very Satisfied Customers... 3M Products are designed for trade use (ie Automotive Bodyshops) and are therefore very high quality and will last you a very long time.
Prices should hopefully be the same as last time if I get enough interest from you lot...
Prices last time were as follows (based on at least 20 people ordering):
3M Perfect It III Cleaner Clay - £16.99
3M Perfect It III Fine Compound - £12.99
3M Imperial Hand Glaze - £9.99
P&P costs will have to be a little higher than before (not much):
1x Clay = £3
1x Glaze = £6
1x Clay and Glaze = £7
All 3 Products = £9
(no one requested just a Compound before, so I'm unsure of Postage costs for that item on it's own... Probably £7)
As with the last GB, many of you will no-doubt want to take me up on the "hand delivery" option, which means that I'll bring your stuff along to the next Cheshire VAG, Midlands Meet or South Yorkshire Meet after the end of the GB. However some of you don't go to these meets, so I will have to post to you.
Make use of this GB, this stuff is good!
