Idling problem - 6n2 1.4 16v - please help!
Dearden6n2
Post by Dearden6n2 »
Right, im getting really upset, annoyed and bloody frustrated!
The problem!
Id say every 8/10 weeks my polo will start struggling to idle! For example come to a set of lights and drop the clutch as im stoping and it'll cut out without struggling or anything!
Upon restarting it'll either...
- struggle to idle an cut out
-idle fine
Ive currently been curing it by wd40 into the throttle body, not loads just a little! And it seems to stop it for 8/10 weeks (may cut out once a week)
The car is overdue a service a little just waiting for payday but im hoping its just a service it needs...
Please help me!... Don't understand how embrassesing it is when it cuts out an people think ive stalled :(
Tom
P9 THD...
Instragram - TDearden1
Tom
P9 THD...
Re: Idling problem - 6n2 1.4 16v - please help!
WD40 should not be sprayed into the throttle body at any cost. It can cause irreversible damage to the throttle assembly
Conduct a full service, including spark plugs, air filter and fuel filter
Clean the throttle body properly with Wynns Intake and Carb cleaner or a similar xylene based intake cleaning spray - Ensure you clean the crankcase breather hose of any oily gunk in it with the spray also.
Perform a TBA (Throttle Body Alignment) with VCDS/Vag-com
You problems should clear up.
