Polo gti 6R cruise control
Robreg5
Post by Robreg5 »
Hello all. Ive got a 2011 polo gti and was wondering if cruise control can be retro fitted. Has anyone done this or have any info?
Cheers :D
KieranLeighton
Re: Polo gti 6R cruise control
Post by KieranLeighton »
Yeah it can be :)
Mart!n-GTI-DK
Drives: '14 Polo BlueGT
Post by Mart!n-GTI-DK »
It should be plug n play... Install and code.
franko247g
Post by franko247g »
Hazzydayz do it so definitely possible :)
http://www.hazzydayz.com/vw-polo-6r-cru ... 1177-p.asp
stuart.cameron
Post by stuart.cameron »
Eddie-gt
Post by Eddie-gt »
there is a fair bit of wiring that has to be fitted which includes running one wire to the ECU and soldering on to another wire
Also the BCM has to be at least one ending 87
Eddie-gt
Post by Eddie-gt »
Fitted Cruise to a (2013MY)Polo R-Line 1.2Tsi today what a PITA
had to solder on to some wires on the BCM and fit terminals into the BCM plug which had to be opened up with little or no room
had to feed a wire to the ECU and the Plug was protected with a cage fixed with snap bolts
All done and working
Robreg5
Post by Robreg5 »
Would the same wires need to be installed on the gti 6r? How much would this installation cost including parts?
Cheers.
Eddie-gt
Post by Eddie-gt »
Parts came in at £130
You would still require the wires
