I've just got a forge 008 and it hasn't got any instructions on the spring set up etc...
I know the different springs are for different boost pressures I think, was just wondering which setup for standard map and if there's snything else I need to do?
Any advice is much appreciated, thanks
Forge 008 Setup
Re: Forge 008 Setup
Running a standard map I've been using the spring that it comes fitted with and it seems to work perfectly, I think you only need to use the other springs when you map the car.
dood9n3
Re: Forge 008 Setup
General ratings
Green should be fine for stock map
Valve Spring color coding
Green - 5-15 PSI
Yellow - 15-23 PSI
Blue - 23-30 PSI
Red - 30 + PSI
Green - 5-15 PSI
Yellow - 15-23 PSI
Blue - 23-30 PSI
Red - 30 + PSI
Re: Forge 008 Setup
So its literally just plug in and play then
the top seems kinda loose aswell where you would unscrew to put a new spring in, i gather i just tighten it up with the allen key, and do i need to do anything with the shims yet?
Re: Forge 008 Setup
I'd just screw it up, although I don't think mine was loose when I got it. The shins are so you can use settings in between those of the springs by pre compressing them.
Re: Forge 008 Setup
Awesome, thanks guys ill get it fitted this weekend
