hose options on 312mm setup
rover220
Post by rover220 »
have got a 312/256mm setup ready to fit but im sure i read on here that the front hoses could do with being a bit longer to accommodate the bigger calipers?
can anyone confirm as im probably going to get some hel braided hoses and i can get the hoses made longer if required
cheers
Crippin
Re: hose options on 312mm setup
Post by Crippin »
I'm unable to answer your question, but where did you buy your breaks from?
rover220
Post by rover220 »
Crippin wrote:I'm unable to answer your question, but where did you buy your breaks from?
Got them of a seat toledo v5 a friend bought for other parts.
I may sell if youre interested
dood9n3
Post by dood9n3 »
OEM lines fit perfectly, just make sure the hole for the pipe is facing up, I fitted mines upside down initially :oops:
aarongti
Post by aarongti »
What else is needed for the 312 set up?
Calipers & carriers, discs, pads, splashguards?
rover220
Post by rover220 »
dont need the spash gaurds.
calipers, carriers, discs and pads
ryanday91
Post by ryanday91 »
standard front lines work fine,
