I have been battling trying to eliminate the knocking noise from my 2007 gti so far I have replaced;
Genuine vw top mounts and bearings L&R
new drop links L&R
cupra console bushes
I plan to change the arb bushes/saddle mount bushes but I have heard 19mm and 20mm just wondering which size people are using?
Whas size poly bush for my gti?
Re: Whas size poly bush for my gti?
Bump, would also like to know answer to this.
- Drives: 6c Polo Blue GT
20mm is the size of the anti roll bar on the GTI guys.
Cheers Joe
Cheers guys, I have bought 20mm ones from Awesome and confirm its 20mm
Been trackin' a couple of 9n suspension posts on here as a guest so thought I'd sign up and pick some polo dudes brains... I'm rollin in an '05 9n gttdi and struggling to find correct code on the sticker spiel under the boot carpet..... Any gurus out there know what diameter the arb is on a 130brake polo gttdi? Thanks in advance guys ...
Anyone know another code option on the boot sticker? Can't spot any OA codes as mentioned on the other relevant arb posts...doh...alitee3 wrote:Been trackin' a couple of 9n suspension posts on here as a guest so thought I'd sign up and pick some polo dudes brains... I'm rollin in an '05 9n gttdi and struggling to find correct code on the sticker spiel under the boot carpet..... Any gurus out there know what diameter the arb is on a 130brake polo gttdi? Thanks in advance guys ...
