9n/9n3 ibiza 6l custom rear springs
Forum rules
Please Use The New FOR SALE CATEGORIES when listing an item for sale!
chewy_
Post by chewy_ »
Pair of custom rear springs. Were fitted to an Ibiza 6L but will fit 9n/9n3's
Not sure exactly how low they go but they go very low as the pic shows. Perfect if you coilovers don't drop as low as you want at the back.Can be used with or without coilover adjusters.
After £ 50 posted
matt_123
Re: 9n/9n3 ibiza 6l custom rear springs
Post by matt_123 »
was the pic with adjusters? or without? im currently running AP coilovers no adjuster, this spring looks like just what I need, only thing is getting the front that low to match!!
chewy_
Post by chewy_ »
They were made for ap coilovers as the back didn't drop low enough. The pic is with adjusters out on 15's
Have you took the helper springs out the front?
matt_123
Post by matt_123 »
Helper springs out the front on AP coilies?? There just wound all the way down lol i would be interested in these if only i wasnt going to get reverse rake... :roll:
chewy_
Post by chewy_ »
On your front coilovers is there 2 springs? A small one at the top and then the main spring? remove the small helper spring at the top and your car drops lower :wink:
matt_123
Post by matt_123 »
chewy_ wrote:On your front coilovers is there 2 springs? A small one at the top and then the main spring? remove the small helper spring at the top and your car drops lower :wink:
PM'd :)
chewy_
Post by chewy_ »
chewy_
Post by chewy_ »
Sold
