Need to know what cooler performance spark plugs you guys on stage two GTi's are using, I've got some NGK PFR7Q plugs but not sure if they are the correct ones for cooler plugs?
Thanks,
Cooler Spark Plugss
Re: Cooler Spark Plugss
Totally irrelavent, whats your MPG on stage 2Polo96CL wrote:Need to know what cooler performance spark plugs you guys on stage two GTi's are using, I've got some NGK PFR7Q plugs but not sure if they are the correct ones for cooler plugs?
Thanks,
Sorry for throwing off topic
Someone confirm but I believe its Audi S2 plugs?
I'm stage 2 and haven't done upgraded plugs, is there any benefit?
I've run genuine plugs on my stage 2 for the past 3 years. Never has a issue, if you want to use a cooler plug the best plug for tuned 1.8ts is a bkr7e
is there any point on stage 2?
Thisryanday91 wrote:is there any point on stage 2?
Cooler Spark Plugss
Yea Audi s2 plugs are correct. Stage 2 is far better than stage 1, it's a noticeable upgrade.
Bkr7e or genuine
