Where is the A/C pressure switch?
I think its underneath the battery somewhere, can anyone confirm this or correct me if im wrong
Re: Where is the A/C pressure switch?
Hi
Its on the drivers side just below and behind the head lamp where the air con pipe drops down, if you take off the fog light grill and remove the fog light you can look up and see it attached to the pipe on a tee,
