I've plugged into VAGCOM tonight and got the above code. Is this the dry solder joint that I've heard about before in the ABS ECU? Does it start intermittently before packing up all together?
I've cleared the fault down and it hasn't come back (tonight). I hope it stays off until at least next Tuesday when it's due it's MOT. I've usually MOT'd it by now but I didn't want to risk a failure before this weekend
