comfort / convenience module?
greypolo9n3
Drives: white 6r 1.6 tdi rline/gti
Post by greypolo9n3 »
Anyone know the location for the above module
told i may need to replace mine due to some of the retrofits im looking at
Mart!n-GTI-DK
Drives: '14 Polo BlueGT
Re: comfort / convenience module?
Post by Mart!n-GTI-DK »
I belive they are part of the window winding mechanism...
rover220
Post by rover220 »
Mart!n-GTI-DK wrote:I belive they are part of the window winding mechanism...
You believe wrong.
b0rk
Post by b0rk »
The BCM is under the dash above the accelerator peddle. Look up and you'll see it and the two wiring connectors feeding it.
Consider very carefully before doing any mods that require re-wiring of the A or B connectors these are very hard to access.
greypolo9n3
b0rk wrote:The BCM is under the dash above the accelerator peddle. Look up and you'll see it and the two wiring connectors feeding it.
thanks, what would need it re-wiring?
b0rk
Post by b0rk »
What are you planning to do?
MFSW or automatic lights or a factory type xenon install all require the BCM connectors to be split and rewired. Front fogs in some instances may also.
It is doable just very difficult and really you need special tools to de-pin the existing connector quickly and possibly without splitting it down.
vc-10
Post by vc-10 »
The MFSW? Are you sure?
b0rk
Post by b0rk »
Slip ring pin 10 (LIN bus) needs to be soldered to BCM connector a pin 17 (violet-white), according to the wiring diagrams.
ThePunisher
Post by ThePunisher »
List of different versions of BCM/Central Electric Control Module available for Polo 6R's:
6R0 937 084 Base
6R0 937 085 Low / medium +
6R0 937 086 Medium + +
6R0 937 087 High +
6R0 937 088 High + + with start / stop operation
7H0 937 089 High daytime running light, driving light assistant and Coming Home Function
7H0 937 090 Max
greypolo9n3
ThePunisher wrote:List of different versions of BCM/Central Electric Control Module available for Polo 6R's:
6R0 937 084 Base
6R0 937 087 High +
7H0 937 090 Max
aah thats brilliant thanks. So does this mean if i want to retrofit xenons id have to get one of the last 2?
ThePunisher
I know a guy who has fitted replicas of the oem xenons, I will ask which module is fitted in his GTI.
