comfort / convenience module?
Posted: Mon Sep 16, 2013 6:12 pm
by greypolo9n3
Anyone know the location for the above module
told i may need to replace mine due to some of the retrofits im looking at
Re: comfort / convenience module?
Posted: Mon Sep 16, 2013 9:43 pm
by Mart!n-GTI-DK
I belive they are part of the window winding mechanism...
Posted: Mon Sep 16, 2013 10:23 pm
by rover220
Mart!n-GTI-DK wrote:I belive they are part of the window winding mechanism...
You believe wrong.
Posted: Wed Sep 18, 2013 2:26 am
by b0rk
The BCM is under the dash above the accelerator peddle. Look up and you'll see it and the two wiring connectors feeding it.
Consider very carefully before doing any mods that require re-wiring of the A or B connectors these are very hard to access.
Posted: Thu Sep 19, 2013 6:55 am
by greypolo9n3
b0rk wrote:The BCM is under the dash above the accelerator peddle. Look up and you'll see it and the two wiring connectors feeding it.
thanks, what would need it re-wiring?
Posted: Tue Sep 24, 2013 2:42 am
by b0rk
What are you planning to do?
MFSW or automatic lights or a factory type xenon install all require the BCM connectors to be split and rewired. Front fogs in some instances may also.
It is doable just very difficult and really you need special tools to de-pin the existing connector quickly and possibly without splitting it down.
Posted: Tue Sep 24, 2013 9:30 pm
by vc-10
The MFSW? Are you sure?
Posted: Wed Sep 25, 2013 9:49 pm
by b0rk
Slip ring pin 10 (LIN bus) needs to be soldered to BCM connector a pin 17 (violet-white), according to the wiring diagrams.
Posted: Sat Oct 05, 2013 2:19 pm
by ThePunisher
List of different versions of BCM/Central Electric Control Module available for Polo 6R's:
6R0 937 084 Base
6R0 937 085 Low / medium +
6R0 937 086 Medium + +
6R0 937 087 High +
6R0 937 088 High + + with start / stop operation
7H0 937 089 High daytime running light, driving light assistant and Coming Home Function
7H0 937 090 Max
Posted: Sun Oct 06, 2013 12:53 am
by greypolo9n3
ThePunisher wrote:List of different versions of BCM/Central Electric Control Module available for Polo 6R's:
6R0 937 084 Base
6R0 937 087 High +
7H0 937 090 Max
aah thats brilliant thanks. So does this mean if i want to retrofit xenons id have to get one of the last 2?
Posted: Sun Oct 06, 2013 5:12 am
by ThePunisher
I know a guy who has fitted replicas of the oem xenons, I will ask which module is fitted in his GTI.
