Hi guys I'm kinda new here so don't really know what I'm doing or if I'm posting in the right place.
But my passenger side electric window refuses to go back up, it goes down fine but when i want to put it back up i have to leave the engine running then put it up little by little then switch the engine off and pull it up with my hands and have someone turn the engine back on while holding the button to send the window up the rest of the way. The window when its down sounds loose and when i bang against the door lightly (also have to do this to get the window to go up) i hear it move around
Anyone know what is wrong or how i can fix it?
John
6N2 Passenger side electric window
Re: 6N2 Passenger side electric window
its usally dodgy relays, they are located behind fuse box if you wanted to change, but one way to go around this is putting your key in door and hold it in lock position, and they will all rise, not a fix but saves you pulling it up for now
- JLM_6N2
- Location: Wendover, Buckinghamshire UK. Drives: 2001 MK5 POLO 6N2
Cheers for that sorry for the late reply, it was a relay but its sorted now
