Just wondering if anyone has had there abs pump replaced and what it cost them so I know roughly what I'm expecting to pay.
Checked fuses which are good, and plugged into vagcom which comes up with abs pump failure.
Thanks,
Andy
ABS pump replacement cost?
gti-joe
- Drives: 6c Polo Blue GT
Re: ABS pump replacement cost?
Speak to VW customer services, they were replacing them FOC a while back as a goodwill gesture due to alot of failures on certain ones.. Otherwise they are very expensive, cant remember exactley how much but around the grand mark to fix.
Edit: Found this thread on one of the forums I use. The guy whose user name is in orange is a VW tech.
http://www.scottishvag.net/viewtopic.ph ... mp#p935084
john.p.clegg
Somewhere I've seen something about a dry joint in the control box that just needs re-soldering...is this the same thing??
John
John
Theres a company out there that can fix the ecu now. Get on briskoda and do some research.
