Page 1 of 2
Show you home lights?
Posted: Tue Dec 31, 2013 12:45 pm
by 6n2stan
Hi, I've jumped over from the 6N2 section as a friend of mine has just picked up his 6R GT.
He was wondering if there is a show you home/lights on with unlock function that I could activate with VAGCOM? My MK5 Golf does it but its got Auto lights/Wiper/Mirror dim. Is this something that anyone else has done or is it a retro fit kit?
Re: Show you home lights?
Posted: Tue Dec 31, 2013 1:13 pm
by Mart!n-GTI-DK
6n2stan wrote:Hi, I've jumped over from the 6N2 section as a friend of mine has just picked up his 6R GT.
It's called Coming Home and Leaving home. And yes it can be coded.
Posted: Tue Dec 31, 2013 2:47 pm
by daydotz
Their was a retro fit for coming home light but I can't seem to find it from kufatec the polo doesn't have it as standard
Posted: Tue Dec 31, 2013 5:04 pm
by Mart!n-GTI-DK
daydotz wrote:Their was a retro fit for coming home light but I can't seem to find it from kufatec the polo doesn't have it as standard
No. There was a retrofit for autolights. But Kufatec dosn't sell it anymore. Too many faults I suspect.
CH/LH lights can be coded.
Posted: Tue Dec 31, 2013 5:50 pm
by 6n2stan
Ace, cheers guys, where is it in VAGCOM? Is it a case of adding a 1 or a 2 to a code?
Posted: Tue Dec 31, 2013 8:16 pm
by daydotz
Mart!n-GTI-DK wrote:daydotz wrote:Their was a retro fit for coming home light but I can't seem to find it from kufatec the polo doesn't have it as standard
Where In Vcd's ? I seem to remember they had a kit for both
Posted: Wed Jan 01, 2014 1:55 pm
by 6n2stan
So, has anyone actually activated this function on a GT then?
Posted: Sat Jan 04, 2014 6:17 pm
by ThePunisher
I activated the coming home lights on my Polo 6R GTI with VCDS.
http://www.pgti.co.za/pgtiownersclub/vi ... ?f=7&t=289
![Image](http://i1198.photobucket.com/albums/aa448/CC-SA/IMG_00002212_zps0b1f7e8e.jpg)
Posted: Mon Jan 13, 2014 3:47 pm
by 6n2stan
Cheers TP, where in VCDS is that setup page?
Stan
Posted: Thu Jan 16, 2014 5:45 pm
by Wilxay
Coming home lights work when you have taken the key out of the ignition and pull the main beam to flash once. Obviously once is coded of course. They turn off 15 secs after u lock the car
Posted: Thu Jan 16, 2014 7:34 pm
by Mart!n-GTI-DK
Mine is set to turn on the LED's and the xenon lights.
![Image](http://www.liljedahl.eu/images/bluegt/chlhlight.jpg)
Posted: Thu Jan 16, 2014 8:37 pm
by Wilxay
How?
Posted: Thu Jan 16, 2014 9:30 pm
by Mart!n-GTI-DK
Wilxay wrote:Coming home lights work when you have taken the key out of the ignition and pull the main beam to flash once. Obviously once is coded of course. They turn off 15 secs after u lock the car
You can set the time for how long they stay on with VCDS. I have mine set to 25 seconds for both coming and leaving home.
Wilxay wrote:How?
It's an option when coding the lights.
Posted: Fri Jan 17, 2014 5:33 am
by Wilxay
Is it under adaptation? And how how've you got leaving home lights to work?!
Posted: Tue Jan 21, 2014 8:18 am
by Norbreck21a
Would also be interested in this Martin for the wife's Blue GT.
I was under the impression that CH/LH only worked if you installed the Auto lighting set-up (which I see you have done). Are you saying that even without the Auto lights, CH/LH can be coded in VCDS to work out of the box so to speak ?
Does this mean (when coded) that the CH/LH function gets added to the setup screen in the MFD, and the light duration etc. can be controlled from there or purely via VCDS ?
Finally, rather than the crappy "flash the headlights" to engage coming home, is there a VCDS option to have it come on automatically when either the key is removed or the door opened (I did this to my new Golf GTD as that was flash to activate as well out of the factory).
Any chance of a little more information please bud ?
