Hi guys,
any1 know the corresponding values/descriptions for the codes that appears in the Climatronic (you must press some buttons first!) of the Polo 9N???
I'm looking for actual internal temp. and actual speed but I can't find out them....
i think the air-recycle the red button (higher temperature) and the economy button. All 3 together.
Code 16 is supposed to be speedometer. I tried and give out only zero.
You must press the first 2 buttons of air flow control (I don't remenber now but I think... down air flow + "face" air flow!) and ECON!!! All 3 buttons at the same time!!!
Yes! That's it! When you press te 3 buttons it shows a tool in the display and the temperature shows "-5,6" going up (-5.6, -5.5, -5.4,...)
Now lets search the net to see if we can find the codes and things!
cool!
