Window Rubbers Not Sealing
- joe2612
- Location: Guildford, Surrey, Drives: Polo GTI 6n2 Black
So i traced my leak down to the rubbers not having a tight grip on the window. Has anyone else encountered this problem before and what was your solution?
Re: Window Rubbers Not Sealing
The window rubbers are more of a water deterrant than a seal. A certain amount of water will run past and out the door drains
How much water is coming through and where is it coming out/going through?
- joe2612
If I pour a watering can over the window, it's like a waterfall entering the door. The passenger side is worse than the drivers. I've sealed both doors with a plastic membrane so hopefully that might stop it..
Have you got the internal window seal strip clipped into place? The doorcard snaps into it at the top
- joe2612
Is that the white strip? Yep have got that in, the water definitely is getting in right at the top.
No it's black. White strip is door card side
Have you got a pic looking down at the seals with the doorcard off?
- joe2612
Hmm, Is the trim visible with the door card on? I'll get the card off and have another look.
Yeah, if you look down the where the glass meets the doorcard its visible
i had this problem on mine i used some washers on the window regulator mounts to make a better seal between the window and the rubber, seemed to have worked ok
